Hello all, Is the LQ4 flex plate and a LS1 flex plate the same? I had my precision stall converter re stalled and they made the motor side snout a little longer so it would bolt up the a LS motor. It fits fine but the snout is all the way in and the flex plate is about 1/4 to 5/16's away from the plate I have and the holes are not perfectly aligned.
If it is different then can I just bolt up a LS1 flex plate? will it be the same tooth for the stock starter on the LQ4 motor?
Thanks
Will
