Results 1 to 4 of 4
Thread: 8.1 rail and injectors
    I'm putting a LS6 in a 1997 GMC.
    I'm wanting to know if I can use a 8.1 fuel rail and injectors?
    Does the fuel rail have a return?
    Is the regulator in the rail?
    please help
    1997 GMC RCSB
    LS6/T56
    Nope, center to center spacing on the cylinder bores is greater on a big block. Injectors should be able to be used.
    So I could use the 8.1 injectors and a 4.8, 5.3, 6.0 rail?
    thanks
    1997 GMC RCSB
    LS6/T56
    You need an LS1 or LS6 rail for an LS6 intake. Performance Products sells billet aluminum rails for under $100. Check out Ebay.
