Results 1 to 9 of 9
Thread: gradual acceleration faster than WOT??
    Feb 2008
    Arizona
    why does it feel that when you leave the line at wot is not faster than when you accelerate gradualy? or am i wrong?? because i feel the truck faster when i step on the gas like 1/2 throttle and keep on it as the truck moves... other that leave the line at wide open throttle...
    how am i supposed to race in the 1/4 of mile?? wot or gradually?
    thanks pals!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Somethin aint right. Mine does that but it is the whipple electronics on mine that are being removed as I type this.
    San Marcos Texas
    It may be the DBW. You would have to look at the actual amount the throttle body is opening, not the amount you push on the gas.
    Feb 2008
    Arizona
    what do you mean by DBW?? so how are we suppose to race in a quarter of mile? always at WOT??
    Wasilla, AK
    Drive By Wire.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    Jan 2006
    No, Its in the tune. If you push your pedal all the way down, your throttle body will not open automatically to a wide open position. A custom tune from Nelson Performance will fix it.
    DBW means drive by wire
    DBC means drive by cable.
    Quote Originally Posted by Felix Arrizon View Post
    12 Sec. Club! SOLD
    SOLD***
    Oct 2007
    connecticut
    actually i have thought the same about my truck too and i do not have drive by wire. its like it chokes for a second or two and then recovers when u just mash on it.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Mar 2006
    Mesquite
    As stated - DBW is Drive By Wire which can be misleading...it just means it's controlled electronically by the computer as opposed to DBC which is a mechanically operated throttle body,
    Feb 2008
    Arizona
    yeah, exactly... my truck does the same... it seems like it chokes for a second, and then it recovers... and it is DBW.. and, i have the nelson tune on it.. i have to say that it is better after the tune but still a little slow at the beginning...
    my friend's 2000 silverado DBC is fast when you step on it.. i mean, no lag on the throttle.. can i get a DBC on my truck? where can i find it? is it worth it? thanks again..
