Results 1 to 10 of 34
Thread: Knock at 10 psi?
    Spring, Texas
    Knock at 10 psi?
    Well after I got my built trans in, I decided to go ahead and crank up the boost to 10 psi (was running 8 before). My AFR was still in the high 10's low 11's and I was only running 12-14 degrees of timing. Yet I was still getting 1-2 degrees of knock and could definitely hear it. Any ideas as to why that would be? Meth was working IAT's were in the 70's which was at or below ambient. Need some suggestions please.
    Apr 2005
    Plugs? Gap?
    Gone, but not forgotten!
    Spring, Texas
    If I remember correctly they are gapped to .035?? Whatever is specified for the STS kit. They are the stock plugs.
    Jan 2006
    TR6 gap at .029-.030.
    Quote Originally Posted by ramair2002 View Post
    12 Sec. Club! SOLD
    SOLD***
    Quote Originally Posted by Jamest View Post
    x2
    casey23 Guest
    Plugs
    X5 !!! Change them ASAP
    Spring, Texas
    I just did. The plugs in the pics were the stock ones that came out. Didn't help any since I think my injectors may be maxed.
    Mar 2006
    Phoenix, AZ
    If they are stock plugs I'd try swapping them out for some colder ones. Try the NGK TR6.
    Other than that, there shouldn't be any reason for it to knock if the meth was working correctly. Might try turning it up a little bit to spray more.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Apr 2005
    Yeah, I was running .028 @ 10 psi.
    Change the plugs & try again.
    Spring, Texas
    Some one have a part number for those and where I can get them?? I've seen a few different types out there. Thanks for the advice everyone!! I'll get them swapped ASAP!!!
