Results 1 to 10 of 34
Thread: Knock at 10 psi?
    Spring, Texas
    If I remember correctly they are gapped to .035?? Whatever is specified for the STS kit. They are the stock plugs.
    Jan 2006
    TR6 gap at .029-.030.
    Quote Originally Posted by ramair2002 View Post
    12 Sec. Club! SOLD
    SOLD***
    Quote Originally Posted by Jamest View Post
    x2
    casey23 Guest
    Plugs
    X5 !!! Change them ASAP
    Spring, Texas
    I just did. The plugs in the pics were the stock ones that came out. Didn't help any since I think my injectors may be maxed.
