Results 1 to 8 of 8
Thread: Heeeeeeelp!!!!
    Feb 2008
    Arizona
    Heeeeeeelp!!!!
    i just got to rocky point! and went to the sand hill to mess around, and just found out that my truck wont go to 4WD LOW!!! everyone is now kicking the **** out of me!!! i just put my new nelson's PCM, shift kit, and servo in... and i dont know why it wont go into 4wd LOW!!! what can i do to fix it??? help pleasee!! i've been doing investments in my truck the whole year for this week, and now it wont work... i cant believe it.. what can i do?? please buds.. help me out with this..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Feb 2008
    Alabama
    Did you put it into neutral will trying to switch
    Feb 2008
    Arizona
    yes sir i did!!! i put it in neutral!! i dont know what to do!!
    Check all fuses, crawl under the truck and see if maybe the solenoid got unplugged when the tranny guy was putting in the new shift kit. Follow the wires and see that they didn't get cut, crimped or melted.
    Yeah, I was thinking the same. There has to be something that was not plugged in somewhere... So, does it go into 4 HI? That is weird because the 4WD actuator should send it to 4HI or 4LO no matter what... Check your connections at the actuator and see if any wires were damaged or crimped.
    faulty dash switch? We all know that they're not known for lasting forever...
    Feb 2008
    Arizona
    yes, it goes in 4wd HI, but when i try to put it in LOW, i can hear the 4wdLOW noise when it is hooked, but then again, does the same noise and get the LOW out again...
    Hmmmm...sounds fishy. I would check all of your wiring connections down there. By doing a servo and shift kit, you should have not even touched the 4WD stuff...
