Oil Pressure Sensor. the 5.3 oil pressure sensor is located at the rear of the block behind the intake manifold. the sensor is very low on the stock block so we used an S&P 16mm adapter to install the vehicles original oil pressure sending unit. the original sending unit provides proper settings for your guages. This is what it says on an S&P write up for a 96 tahoe 5.7 liter to 2002 5.3 liter swap. Is this a must to do it this way or will it need to be done for the guage to function properly? Does anyone have different ways of doing it. they used the S&P harness i will be using my factory harness reworked by nelson performance. this and the engine temp sensor are whats bugging me about the swap. Thanks all! I appreciate the help!
