Results 1 to 10 of 14
Thread: fuel injector cleaners???
    Hey everyone,
    Has anyone ever used a good fuel injector cleaner? My truck now has 120,000 on it and I'm looking to do some kind of system cleaner. What about those decarboning total cleaners? any thoughts or opions? Thanks
    Jeremy
    2000 Sierra 4x4 Denali front, 5.3, 3/4 drop, 22 foose speedsters, roll pan, Cold Air, Cat-back.
    peopl euse seafoam, but that stuff can be dangerous. lucas injector cleaner works really good
    seafoam in the fuel tank is safe. my local walmart store does injector cleaning with BG products, I think it was. They disconnect the fuel line and fuel pump fuse and then start and run the truck on pure injector cleaner pressurized by air.
    Anyone Else ever try this sea foam? Ive heard people say that it messed up there trucks. that and I don't think i could ever let walmart touch my truck.
    Jeremy
    Jun 2007
    i think u should use seafoam.lolj/k i thought it would be like that gameshow .number 1 anser IS SEAFOAM.hahaha.i know that answer with my ears closed on here thats freakin funny.but it is good to see the other sugg,tooo ,bcause theyre is alot of other acceptable inj cleaners out theyre,the one red mentions works well and bg profucts are great also.lucas profucts work well 2 tho.so toss it in a hat and use what comes out.i like gregs idea tho i would do it because i did the same exact thing with my inj,and bg products with a machine they use for this i whatched this happen right in front of me thats y i know it works.i held the fuel rails and the other guy pulled the trigger .do it its fun.
    Jun 2007
    Quote Originally Posted by ramsey rider View Post
    i guess what i mean is if u see ut happen your more apt to believe it.ya know .?
    Feb 2008
    Alabama
    Yep seafoam rocks
    Eastern Idaho
    One of the guys on another forum I frequent swears by Chem Tool.
    Fuel Additives
    Here is the thread. Caution, it's a Dodge site. Yeah, I've got a Ram too, don't shun me.
    4x4dodge :: View topic - Adding ATF to your gas tank. [ Guest ]
    He recommends the second one down. It says it's a carburator cleaner but it works for injectors too. To be honest, I've never been able to tell much diff. after using any cleaners. I did use the Chem Tool and will again, but I think it's kinda like a vitamin thing. I don't feel a thing on a daily basis but I know that in the long run they improve my health. I wonder if this is the same. I might not feel anything but it keeps things clean so there is no slow degredation. I also have a friend who was the shop forman at a Chevy dealer for years. He swears (actuall swore by, he passed away November) that adding a can of ATF to your tank does just as well plus it helps to lube things as it goes through. Once again, don't know how good that is but at the same time there is usually a bit of fact behind those old folk remedies. I tried it and like with all the other cleaners I've used couldn't really tell anything. I think I'll keep using the Chem Tool just because, well I don't know why. I guess that's a lame reason but I figure it can't hurt.
    This is what I've seen used from BG... BG Company
    Feb 2008
    BG's 44K is good stuff,it's not a miracle power adder or anything,it does clean up some of the muck though.
