Results 1 to 5 of 5
Thread: New LS1 Startup
    Mar 2004
    How do you prime a LS1 after its been sitting for several months? I've got an old distributor that I used to use with my chevy engines, but this thing doesn't have a distributor!! HELP!!
    There is no way to prime one. The oil pump is driven off of the crankshaft. If you are really concerned you can pull the spark plugs and crank it for 15 seconds or when the oil pressure gauge starts to register. A couple months should be no problem. Cars sit on dealer's lot longer than that without being started. Your only other alternative is to buy a remote oil cooler adapter and use air to push a reservior of oil through the galleys. I would not worry about it, personally. Pull the plugs and crank it if you are worried.
    May 2003
    you will be ok! Fire that bad boy up! Just keep an eye on your oil pressure gauge, if it does not register in a few seconds the turn it off! :
    2005 RCSB 4.8L TVS1900 9 psi
    2005 ECSB 4.8L TVS1900 5 psi
    That makes 9.6L @ 14psi
    Oct 2003
    LaPorte TX
    :stupid:
    2010 Camaro 2SS/RS
    2020 GMC Sierra AT4
    San Marcos Texas
    When I did mine I just left the fuel pump relay out and cranked it until it read oil pressure, then reinstalled the relay and fired it up.
