Results 1 to 7 of 7
Thread: 4.3 To ls-1 what do i need
    Feb 2008
    eastern ky
    Ok guys here we go I have a 2004 silverado 4.3 5 speed 4x4 And i have just bought 1995 ls-1 from a friend I need to know what parts i need to do the swap such as motor mounts,fuel pump,fuel lines,etc. I am planning on keeping the 5 speed trans so which flex plate do i need to use. and also does anyone make a stand alone harness for the 95 ls1 any info would be great thanks.
    Nov 2006
    Mesquite, TX
    95 didn't have an LS1...the first year of the LS based motor was in 97 in the vettes.....what you prob have is an LT1
    True, no LS1s in 95. Take a pic and post it up and we'll let you know what you have. What did it come out of?
    Feb 2008
    eastern ky
    Thanks for the quick reply you are correct it is the lt1 from a 95 camaro
    Dont waste your time. The first time you go in for an inspection they will laugh you out the door and tell you the truck has an illegal swap according to CARB regulations that most states have adopted. Your V6 has almost the same HP as the 05 Fbody LT1 had.
    Feb 2008
    eastern ky
    Thanks for the info havent picked the lt1 up yet and glad i havent. will look locally for ls1. still need the other info when you get time.thanks for saving me alot of trouble.
    Apr 2007
    Utah
    Generally you need an engine that is the same year or newer than the year of the truck. at least that is the way things are here.
    Anyone know something different?
    1990 K2500 with Hummer Kit Body, LQ4, 4l80e 4x4
