Results 1 to 5 of 5
Thread: charging issues
    Jun 2007
    charging issues
    okay heres the sich.i have a 145 amp alt and 2 batteries,but when i have my plow on if i hold the joystick for over like 2 seconds ,it just about kills my dash lights .i know its typical for it too draw but it burries the gauge .i dont know y i have all precautionary measures but i didnt have these issues for the last 2 years.do i have a bad ground maybe or could it be something else.opinions please i need too start figuring this out b4 something blows.also if i have my beacon light plugged in or rear defogger on its even worse .were do i start looking ?or what do i start looking at?thanks.
    Oct 2007
    connecticut
    sounds like u have a bad connection somewhere, plow wiring harness's can be a bitch to troubleshoot. a plow dealership should be able to help u quickly, even over the phone prob.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Jun 2007
    i still like too diagnose and suck up the knowledge .lol.since the plow dealrship i bought it from is only about a 1/8 mile up the rd.it just dont seem right i took all these steps 4 precaution and its still doing this.last year it didnt do this ,same setup.if i use my beacon ,even my heater on high it makes it worse .i checked both batts today and theyre putting out proper amperage.so im thinking either ground or pump on plow is drawing more as it gets older .ive heard that electric plows do that with age..im open for INTELLIGENT sugg.[dont mean u yellow ]
    Since you want INTELLIGENT suggestions, I will go ahead and chime in...
    Ok, when did this start? Was it working fine before? Did it happen all of a sudden, or has it progressively become worse?
    With your 145A alternator and two batteries, you shouldn't be having any issues at all. I would start doing the easy things...check the connections at the alternator. And then if they are fine, check the wires leading from the alternator. Check ground wires from the plow. You will have to comb through a bunch of wiring to make sure your connections are solid, but like you said--you will have a better knowledge of your plow's wiring setup.
    You may also consider just taking the alternator off and going to VatoZone so they can test it to see if it is working properly. For all you know, the alt. could be on it's way to the poop chute...
    Jun 2007
    well after a simple diagnosis this morning.truck wouldnt start,lol .i went to my shop and discovered that the battery somehow only had 1/2 the ccr it should have .i pulled the batt replaced,plus i got too find some acid infested issues,like rotted windshield washer lines.lol.then i got too do something ive been wanting to do for awile,rerun all my positive and nigertive wires to dedicated top post,i got a dual post batt for that reason.thanks for all the input anyway always appreciated.
