Results 1 to 10 of 24
Thread: Is this the heart transplant place?
    please delete
    please delete
    Jun 2007
    maine
    wow dude that is a beautiful truck i frigen hate stupid people who ruin it for everyone else... Drunks suck. An ls1 would be amazing in that thing all show and go haha keep us posted!
    Dec 2003
    Newark, Tx.
    see if you can get some 241 heads instead of the '98 heads. They flow better and should only be $200 or so. You will need valve covers and coil brackets too though. Truck looks great.
    Holy Crap Batman. I bet you cried. I would have. Welcome aboard. The guys here have LOOOOOOOTTTTTTTSSSSS of great info.
    Your Truck was and is going to be saweeeet.
    please delete
    Dec 2003
    Newark, Tx.
    Quote Originally Posted by Kruznlow69 View Post
    well, i am new to this world, i've been reading, re-reading, and re-reading again the conversion pages and links and wow its a lot of info. i do plan a tear down of the motor b4 final install. full re-ring, bigger cam, mainly for new seals and gaskets and to check bearing wear. i am just curious as to if i should find a newer ls1 01-02?. this seems like a great deal. thanks for the comments!
    Steve
    If you are going through the block, then it will be fine for what you are doing.
    For extreme applications, there are better, but yours will do fine.
    Oh, with a good cam, tune, and exhaust, you can easily reach high 300's to the wheels.
    Are you wanting a smooth idle, lope, or really aggressive?
    What A Clean Truck Bro!
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    please delete
    no i didnt cry, i kinda let out a few VERY loud obcenities in the middle of the street, then went and had a beer.
    i dont own the 98 ls1 yet, but close.. thats why i ask about finding a newer one. as for idle, a little lope is good. from my research so far i need to figure out an a/c setup, and headers yet. harness will be a nelson custom. i am limited with headers with the body drop, everything gets tighter. the body is coming down 2.5" so even l31 longtubes wont work (i know ls1 and l31s are different). Are those stock manifolds that bad? they look way better than any stock l31 manifold..
    with that body style you are limited on headers as it is
    i have a 98 im dropn a 6.0 in and the only headers known to fit are shortys. we have a member who is making a set of long tubes but with your drop i dont think they would fit. as far as a/c you need a relocating kit and Sanden 508 compressor. gl fitting that in your small motor bay with the drop i dont know if u can get it to fit
    welcome to the site.. did you get money from the wreck? i consider that totaled because the paint job
    I imagine that once you have lowered the body onto the new design frame you will have to create some custom headers for your setup. That frame looks cool. Since you are designing your own frame you could think about modifying the section near the engine to use production headers from another make such as a Corvette. The location of the down tubes would be closer to the center of the head.
