Results 1 to 10 of 15
Thread: 3600 stall question?
    Are yall having to run transmission coolers with 3600 stall converters with your full size trucks? What is the best converter out there?
    SugarGrove WV/Eubank KY
    you would def. need a tranny cooler with a 3600. i run a cooler with my 2600 converter.
    also i have installed alot of coverters and i really like yank. ive never had one go bad on me or my customers.
    Spring, Texas
    As far as converters go, Vigilante is probably one of the best but you will pay for it. My Yank is doing just fine.
    For the trans cooler, you might want to look into a TruCool 40,000 GVWR. It'll keep your temps where they need to be or in my case much lower (50 degrees below ambient)!!!
    Aug 2005
    St. Anthony, Indiana
    Quote Originally Posted by ramair2002 View Post
    Can you explain this? Your Trans temp would be waaay to cold.
    Damn, I need one of those. 40 degree tranny temps in 90 degree weather. Just bustin' on you
    Spring, Texas
    Sorry....meant above ambient!!! Basically when we have the cold weather like we've been having (40's) my trans temps stay around 95 - 100!! I think I need to get a bypass!!
    Apr 2005
    I just stall it up more to heat it up!
    Gone, but not forgotten!
    What do yall suggest as transmission cooler for a 2000 Z71 that is not a difficult install.
    Aug 2005
    Tru-Cool MAX transmission cooler with external thermal bypass: Bulkpart transmission parts don't use the hose clamps that come with it. go to the parts store and get some fuel injection hose clamps.
    Jan 2005
    Humble/Houston TX
    tru-cool 40,000 is the biggest cooler on the market. thats what i run and love it. the only problem is mounting the monster hahaha. it looks like an intercooler
    old mod list: H/C/I/N/E/G 408
