Results 1 to 6 of 6
Thread: 4.8 heads
    Bakersville, NC
    Cool 4.8 heads
    can any of you tell me what would be a good set of heads to go on a 4.8
    Any good flowing ported head with the same CC value as what is in your vehicle. You can decrease the CC size to raise compression if going NA or increase the CC size to lower compression for forced induction at a later date. Trick Flow, AirFlowResearch(AFR), Patriot Performance, TexasSpeed&Performance.....
    Bakersville, NC
    4.8 heads
    what would be the best bolt ons to get the most out of this engine. so far i have true duals with 40 series flows, helix power tower, bbk 80mm TB, and a k&n 77 series intake.
    ff_jeff Guest
    Nelson Performance tune. Look at the top left of the page. 35hp 1 second off 1/4 mile better gas mpg. best investment because free retunes so it will grow with your truck
    I love mine, best thing ive ever bought for any ofmy rides.
    http://www.ls1truck.com/forums/newbi...tml#post112226 my video after tune
    Castro Valley, CA
    As Far as heads go, i too have a 4.8l, and have talked to a guy by the username of Gator on here, and he has the 243 casting heads, and has had some great results out of them... He's a real cool, and easy guy to talk to maybe pm him and ask him any questions... If i remember correctly, those heads come out of like the gto's or something... you can find them on Ebay..
    2004 4.8l 6 speed manual 2wd
    Looks: 22" foose rims with Fierce tires, SS front bumper, SS Front Grill, 2/3 lowering kit.
    Performance: Volant Intake, 3" exaust with Spintech muffler, Pacesetter LT's with Y pipe, TR cam 220/220 .551 112 lsa, T56 Tranny with the Keisler short Shift kit and LS7 Clutch, Quicktime Scatter Shield, ASP Underdrive pulley kit, Dyno tune by Rick at Synergy Motorsports
    Soon to Come:Eaton locker, Electric Fans..Does it ever End?
    Yeah, 243 heads were originally Corvette LS6 heads and then they started putting them on the 6.0L GTOs minus the longer sodium filled valves. You'll lose some compression but be able to add more timing.
