Results 1 to 10 of 19
Thread: 10 psi question
    Jul 2007
    eastern shore of virginia
    10 psi question
    ok, i have a 10 psi pulley sitting on my counter and its killing me. now my silverado is running 9psi, on stock injectors, with the boost pump raising the fuel pressure, and FMU regulating. my wideband is showing perfect air to fuel ratios right up to redline. now heres the thing, i am putting a bung on the sub tomorrow so i can switch my wideband back and forth between the two trucks. if i put my 28lb injectors back in and get a new tune will i be able to run 9-10 psi as long as i watch my a/f ratios. or do i need a pump and FMU. i think if i keep an eye on things and keep my meth working for safety.
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    I would not risk it.
    Jan 2006
    I think you need bigger injectors to run 10 psi. I bet the 28s are way maxxed out.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jun 2007
    anything over9 i would go bigger 42 lbers from the 8.1liter im pushing 12 psi of boost and im starting too run out at 6200 rpm.dont chance it !good luck.
    Apr 2005
    Eventually, you will end up with this feeling...
    Gone, but not forgotten!
    Jul 2007
    well, I'm running 9 psi on the stock 21 lb in the silvy, but i know what you mean. damn it. that pulley is calling my name. well, if i get some 42's will the stock pump put out enough to run them? because i am getting LT's and ORY, and i know from the silvy that you have to richen it up after adding headers. so with 42's and headers will the stock pump still be up to it?
    Mar 2006
    Dawson Springs KY
    Quote Originally Posted by the_jester View Post
    I was seeing 110-115% duty cycles on my stock 28# injectors at 10psi even with a 10:1 FMU. (With the 10:1 disk in it I've seen it peg my 100 psi fuel pressure gauge.) Probably the only thing that saved me from damaging something was the fact that I was spraying meth.
    I now have 42# and they run about 80% duty cycle. I still have the FMU but dropped back to a 6:1 disk in it. It barely moves my fuel pressure now. I may see 65psi at full boost.
    IMO you need at least 42# injectors.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    Jul 2007
    well, im hard headed so i went to iroczone and used their injector calculator to find out exactly what size i need. and at 450 hp at the crank it says i need 42's to run under 80% duty. so i guess everyones right. i just need to suck it up and get some.
    IROCs run 43 psi of fuel pressure unlike our 50-58 psi regulators. We get even more flow from the injectors than they did. I'm not sure what calculator you used on their site.
    Jul 2007
    i just used the 43.5 that was set thanks for the info. i'll check it out with our pressure. how big do you think i can go on 42 lber's
