i have a 91 chevy 1/5 ton with the 10 bolt rear. i have the gear, complete bearing kit and everything else i need to swap the gears because a buddy was going to help me. he and i are on different shift now and not able to do it. what is a good shop to go to in the fort worth area to get the gears put in and the bearing replaced. and I do mean all the bearing both axle and carrier. it is an open rear and going to stay that way for the time being since i dont have the cash or need for a posi unit yet. i dont think the v-6 will spin a tire unless its wet. but the bearing are starting to howl and well as the gear and the axle seals are starting to leak a little bit. thank in advance...
