Results 1 to 8 of 8
Thread: Garage Sale Blow Out!! 4 Pages Of Parts!!!
    It's coming to the end of the year and we need to clear out some parts!!! Some are new and some are used parts. Feel free to take a look and order when needed. Here is a link to view all of our Garage Sale inventory.
    Garage Sale Link
    Thank you!
    Sean
    Does that electric fan harness work for fans out of any style of car/truck? It says camaro fans, but could I use 05 truck fans?
    You got my attention and order! Thanks for the great transactions in the past.
    Thank you for the order. As far as the fan harness it will work for any fans you want to use. You will just need to change out the connector to match.
    Thanks!
    Sean
    Added more to the order. Toss that fuel filter in there with it will ya.
    Quote Originally Posted by Speed Engineering View Post
    Thanks!
    Sean
    Describe more on the "connector."
    Thanks for the order!
    Sean
    The connector that is on the harness is made to fit the F-Body electric fans. If you want to switch out the fans to something else your more then welcome to, but you will need to cut the connectors and soder in the correct ones for your fan option.
    Thanks!
    Sean
