Results 1 to 10 of 11
Thread: Air filter directly on throttle body coupler size?
    I have seen tons of people that have the MAF right off the TB then have a cone filter. Of course I cant find pics now that Im wondering about it. Anyway I am a little confused on what size rubber connecter I will need, cause rubber will obviously stretch. The TB on my 02 6.0 is 4 inches. and the MAF is 3.5 Im told (havent bought it yet). So I wanna get the pieces to have this part of the swap out of the way. AN intake really wont work, its a rockcrawler with no inner fenders. I also need to figure out what size cone filter (3, 3.5) to go on the MAF. Thanks for any advice.
    So, since it is a rockcrawler, it will be a homemade setup with the factory MAF? Measure the O.D. (outter diameter) of the TB. Then take the MAF with you to Home Depot and match it up with black plastic couplers in the plumbing section. As for the cone filter, take the MAF with you to a performance shop that sells a lot of filters--ask the manager if you can start opening boxes and see which one fits on the MAF... I know that is the redneck way to do it, but it is the best and fastest way to get it done. No down time for people to call you back, no shipping down times, etc.
    Mar 2007
    Rockwall, TX
    My MAF was 3". i went to Lowe's and bought some black rubber plumbing fittings that were 4" to 3", and they worked perfect.
    i had to elbow off of the TB with a 4" elbow, use a small piece of 4" PVC into one of the 4" to 3" fittings, then went to the MAF, then went through one of the fittings, through another small piece of 4" PVC, then up to the 4" cone filter.
    very redneck...lol
    Yea, I meant no kit, like FIPK. But I just left my buddys house who has a brand new K&N in the box that he will give to me and its 3.5" ID so I will try and make it work with that, think I will have to use a 4" 90 though. I guess I really just need to buy a MAF as my motor didnt come with it.
    The Fbody MAF is 3-9/16 if I remember correctly. I have 3.5" aluminum tube going from the MAF to a huge K&N filter. See photo below.
    Well, i went to lowes and home depot and neither place has a rubber coupler for my 3.5" MAF. I guess I wil look for a plumbing supply.
    Oct 2005
    I had no luck finding one locally, but ordered one from sylinmotors.com
    There may be better places or cheaper ones, but they have several options.
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
    I need to find a 4" to 3" reducer for the TB to intake tube and cannot seem to find one.
    Aug 2005
    St. Anthony, Indiana
    Quote Originally Posted by silveradoreb View Post
    Intake Pipe Reducer
    4 ply Silicone Transition Couplers
    Silicone Reducer and Transition Hose - StylinMotors.com, Stylin'Motors Inc.
    Wow, thanks, the first link had everything I needed, Can believe I couldnt find those before.
