Results 1 to 8 of 8
Thread: Lifter preload
    Jun 2005
    Way up in North Dakota
    Question Lifter preload
    Hello, Can any one tell me what is the ideal lifter preload for a stock 2002 truck 5.3 lifter?
    I have heard too much cuts performance, too little rattles.
    I heard that they have .090" travel --- so that .045" is ideal. Is that right?
    What is the consensus out there on the WWW?
    Thanks
    2002 GMC 1/2 ton Sierra,4WD, Xct cab, camed, mid-length headers, Nelson tune, electric rad. fan, trany cooler, Heavy 5750 lbs with topper.
    I'm not too sure it's that big of an issue on the gm factory hydraulic lifters. You can bolt a set of 1.75 or 1.85 rockers on the engine without replacing lifters of shimming the rocker stands. You'd think you'd have to shim the stands up for the larger lift since even at the bottom of the lobe the lifter plunger would be compressed further in.
    Jun 2005
    Thanks again-- Mr. Redheartbead
    If you want to go for all-out performance get you a solid lift cam and lifters. Hydraulic lifter cams bleed off compression and performance at high rpms.
    wondertruck Guest
    what lifters and what rockers are you using?
    wondertruck Guest
    solid roller isn't worth it on anything less than an all out race motor. trust me, the additional costs aren't justified on a street motor
    Jun 2005
    Quote Originally Posted by wondertruck View Post
    Stock GMC 5.3 lifters in my 2002.
    Comp Cam Roller Rockers 1.75.
    C Cam bumpy stick from Nelson Per.
    C C harden Push sticky things.
    GM Z06 valve Springy things.
    This is to get better gas mileage , just ask my Wifey thing.
    Don't forget the Thorly Tri- Y's.
    PS, I am spending more on a complete remodel of the up stairs bathroom so wifey can't complain and that's me doing all the work.
    Sorry, I couldn't keep my answer short, back to work.
    Jun 2005
    No high rpms, trying to get better gas mileage so I don't have to buy a car for the highway.
    We have a 1985 Toyota Van since it was new, and that is our around town beater. I used to pull wrenches at a Toy Dealership---22 years ago.
