Results 1 to 5 of 5
Thread: Quick radiator Question
    Well my radiatior got a little crack in the plastic so my truck is down. I'm planning on upgrading to a 34" radiator. It is a direct bolt up right? What else do I need to install it? Forgot to mention the radiator I plan to use is from a 05-06 silverado.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    You'll need radiator hoses to fit a truck with a 34" radiator.
    Thats all? Just don't want any surpises. Are the 34" radiator hose longer or what?
    Yes. The hoses are slightly longer. Make sure to see if the tranny cooler lines match up or if you can fabricate the existing lines to fit with the new rad. Are you doing the 05 electric fans also?
    Got the radiator in. No problems at all. All I had to buy was the antifreeze since my motor is an 05. Right now, I have impala efans but will soon switch to the OEM efans
