im installing a aeromotive fuel pump and a electric fuel pressure gauge .does any one know what pressures i should set it at 1 is idle and 1 is throttle pressure .i think idle is 50 and idk about throttle .i have too hook it too the tach wire wil that do it or with the s/c do i need too set it higher .i have a 6.0 w s/c and bigger inj from 8.1 liter .been through 2 warlboros and now i spent $1000.00 on this unit so i want it right .thanks for any help ill be checking periodically through the day im doing the install today .
