Results 1 to 4 of 4
Thread: Moving Battery and MAF???
    May 2007
    I was thinking about fabbin' up a nifty little air intake on my once I get my electric fans in... I want to put my MAF sensor right in front of my throttle body. From there, get a t-shaped pipe (kind of like this polished piece... http://www.westcoastcorvette.com/p-377-c5-...tem-chrome.aspx ), and add on some more pipe and silicon connections and put a cone-style filter behind each headlight... I could also make little insulated walls around the filters to keep the incoming air cool... Maybe remove my headlights at the track for some good air... Now this also raises the question of where I could put my battery... I was wondering if I could put the battery behind the coolant overflow tank.... Any ideas??? Sugesstions???
    edit: If that link doesn't work for you, try this one... Same part, just in ABS plastic...
    http://www.proformancemotorsports.com/corv...take-01-03.html
    2002 Silverado 2wd ecsb 5.3 4L60E 3.73 Headers, 160* thermostat, TBS, Redneck RamAir, Descreened MAF, Coolant Bypass, Air Gap, Dumped exhaust, LS1 fans,Wheatley tune mid 14.'s...
    http://www.dragtimes.com/Chevrolet-CK1500-...slip-11744.html
    Jan 2006
    <div class='quotetop'>QUOTE(MrLM7 &#064; Jul 7 2007, 04&#58;19 AM) [snapback]98868[/snapback]</div>
    I was thinking about fabbin&#39; up a nifty little air intake on my once I get my electric fans in... I want to put my MAF sensor right in front of my throttle body. From there, get a t-shaped pipe (kind of like this polished piece... http://www.westcoastcorvette.com/p-377-c5-...tem-chrome.aspx ), and add on some more pipe and silicon connections and put a cone-style filter behind each headlight... I could also make little insulated walls around the filters to keep the incoming air cool... Maybe remove my headlights at the track for some good air... Now this also raises the question of where I could put my battery... I was wondering if I could put the battery behind the coolant overflow tank.... Any ideas??? Sugesstions???
    edit: If that link doesn&#39;t work for you, try this one... Same part, just in ABS plastic...
    That would be sweet. Get some pics up when you finish.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    Sounds great&#33; I&#39;ve seen setups with the battery behind the coolant tank.
    Could always move the battery to the bed of the truck for better weight distribution.
