is the 500 rpm over stock going to make the trans run to hot? i'm not sure if the stock cooler will be efficient enough.
05 5.3 RCSB, K&N CAI 77, MSD 8.5's, NGK's, NELSON TUNE, 2"-4" G-Force, HKR Max Flow, TB STALL, 28k Cooler, Vette Servo, 160 Stat, Xenon lamps EveryWhere, 10k H.I.D's, Smoked LED 3rd brake Light, Smoked Tail's, 15% Tint, 45% WS Tint
1967 Nova 358 ci Dart Pro 1 Heads Port matched to Vic. jr, 250/256 solid cam, Hooker Headers ceramic coated, Super Street Fighter Stall, Hipsters Transbrake, 9 inch w/ 4.11's, 26x10.5 Et streets, Lo-pro Caltracs
It probably will be efficient enough, but remember heat kills a tranny. It wouldnt hurt to ugrade it.
i have a tb stall behind my 6.0 and it rose the temps from 165-170 to around 190-200. but i'm also down here in florida with the bad azz heat. so i just got a tru-cool 4590 cooler (28,000 gvw) and it took my temps back down to 160-165. its working very well and it was easy to install.
04 AWD Black Silverado SS http://s179.photobucket.com/albums/w319/meanasstruck2/
Mods- Wheatley Tune, 160* Stat, Zippy Shift Kit, Trailblazer Stall, Tru-Cool Cooler, Volant CAI, Corsa Sport Catback, Jet-Hot Coated Pacesetter LT's, High Flow Cats, Precision EZ Solid Grill, tinted taillights & windows, antenna delete, chrome SS bowtie, stainless bumper duct surrounds
Future Mods- Goodmark cowlhood, E-Fans, P&P TB, and more bolt-on's. (if there is any left)
It really isnt gonna hurt you to get another one..There cheap...and tranny temps are the #1 killer of trannies....its a fool proof 80$......
or you cna ahve three....![]()
http://i92.photobucket.com/albums/l3...gray1qb1-1.jpg
<div align="CENTER">99 5.3-Comp XTR 212/218, 918's, ASP Crank/Alt Underdrive, TB bypass, Long Tubes, high Flows, Xpipe, Dual Flowbasterds, 2.5" Stainless, AEM Intake,TB spacer, 160 Thermostat, 32# injectors, NGK Iridiums, JBA Wires, Flex-a-lite Duals, Canadian Performance Tuned.
4l60E - Trans Go HD-2, Aluminum Accum. Pistons, Zinc Spacer, 2nd Gear Sonnax, 4th Gear Sonnax, Rebuilt, 2600rpm Yank, 3 trans coolers
</div>
<div class='quotetop'>QUOTE(DirtySSouth @ Jul 6 2007, 08:05 AM) [snapback]98777[/snapback]</div>hey dirty,i have a tb stall behind my 6.0 and it rose the temps from 165-170 to around 190-200. but i'm also down here in florida with the bad azz heat. so i just got a tru-cool 4590 cooler (28,000 gvw) and it took my temps back down to 160-165. its working very well and it was easy to install.
have you ran your silverado @ the track yet? also do you have any pics of your truck, it sounds like it's pretty cool.
Spend $50 and get the cooler
If your truck doesn't have a cooler get one. If you have a stall convertor, get a big cooler. If you tow with your truck, get a good size cooler. If you live in a hot climate, get a transmission cooler. If you haven't figured it out yet, GET A TRANS COOLER!BTW, if you have a small diameter torque convertor you probably should buy a larger capacity transmission pan, also. I lost over 2 quarts of fluid capacity when I changed convertors. That means all the heat is now in a smaller package and it will heat up much faster than before. I have a bigger pan on my list.
<div class='quotetop'>QUOTE(RedHeartbeat @ Jul 8 2007, 08:57 AM) [snapback]98944[/snapback]</div>hey right on guys,If your truck doesn't have a cooler get one. If you have a stall convertor, get a big cooler. If you tow with your truck, get a good size cooler. If you live in a hot climate, get a transmission cooler. If you haven't figured it out yet, GET A TRANS COOLER!BTW, if you have a small diameter torque convertor you probably should buy a larger capacity transmission pan, also. I lost over 2 quarts of fluid capacity when I changed convertors. That means all the heat is now in a smaller package and it will heat up much faster than before. I have a bigger pan on my list.
the 28,000 gvw 11x11x1.5 inch cooler that dirty south recommended looks to be legit. it will now be on my list. BTW does anyone have a part number for a larger trans pan? for the 2005? thanks
<div class='quotetop'>QUOTE(fuj357racing @ Jul 8 2007, 12:07 AM) [snapback]98924[/snapback]</div>I am going to the track in a couple of weeks to see what it's runnng and i'll let you guys know the results. and thanks for the compliment. here is some old pics of the truck, i will get new ones up when i can.hey dirty,
has anyone installed the 4th gear servo with their corvette servo? i have a link to go to:
http://cgi.ebay.com/ebaymotors/700r4-4L60-...sspagenameZWDVW
what do you think about installing them both in a mild truck.
