Results 1 to 10 of 10
Thread: Mcgaughys Suspension Q's
    Jun 2006
    im looking to lower my truck 2'' 4'' and was wondering if anyof you guys have had experience with this company. i wanted to use the spindles in the front. and i was also wondering if i can expect to to run into any suspension problems such as broken tierods every now and then, or things of that nature.
    thanks,
    preston
    05 Chevy Silverado. Regular cab, short bed.
    -4.3L
    - Sung Top tonneau bed cover.
    imco custom dual exhaust,
    custom air intake,
    ls1 build in progress..
    May 2007
    there isnt really any problems with the kit, its nice. Mcgaughty's is teh best stuff around as far as I am conerned. I ahvew used Belltech, DJM, all that, but Mcgaughty was spot on. I have a great seller for it PM me.
    ID suggest a notch or helper bags
    http://i92.photobucket.com/albums/l3...gray1qb1-1.jpg
    <div align="CENTER">99 5.3-Comp XTR 212/218, 918&#39;s, ASP Crank/Alt Underdrive, TB bypass, Long Tubes, high Flows, Xpipe, Dual Flowbasterds, 2.5" Stainless, AEM Intake,TB spacer, 160 Thermostat, 32# injectors, NGK Iridiums, JBA Wires, Flex-a-lite Duals, Canadian Performance Tuned.
    4l60E - Trans Go HD-2, Aluminum Accum. Pistons, Zinc Spacer, 2nd Gear Sonnax, 4th Gear Sonnax, Rebuilt, 2600rpm Yank, 3 trans coolers
    </div>
    They make quality products. I ran their spindles on my 92 and the truck rode and drove very nice without any bumpsteer problems.
    Jun 2006
    sweet ya im not ready to do any cutting.....ie: notch. but i was wondering is the carrier bearing relocater kit necessary? and is your ride quaity still decent? and are my stock wheels 17&#39;s? because i saw that you have to use 17&#39;s or bigger in order to run the new spindles.
    -4.3L
    custom air intake,
    <div class='quotetop'>QUOTE(05chevydude &#064; Jul 1 2007, 11&#58;17 AM) [snapback]98285[/snapback]</div>
    They should be 17&#39;s on your truck. Go ahead and run the 17" spindles if you do go mcgaughys. I enjoyed the 2" spindles and the 4" kit, but now Im at a 4/8 and I so Im running a different setup
    This is a post from a very very knowledgable guy on SSS
    http://www.silveradoss.com/forums/in...howtopic=19199
    any one know how difficult it is to change spindles?
    I want to do a 2 4 drop also.
    <div class='quotetop'>QUOTE(zeake &#064; Jul 1 2007, 04&#58;51 PM) [snapback]98300[/snapback]</div>
    It&#39;s not bad at all just make SURE you dont tear up the grease boots because then you have to replace the entire upper and lower control arm just for the boots. I tried universal boots but they just wouldnt hold grease.
    Aug 2003
    Spring, TX
    i&#39;m running mcgaughy&#39;s 2" drop spindles and i did notice a little decrease in turning radius. not all that important because the only time i would be making a tight turn is in a u-turn situation.
    as for breaking tierods, i haven&#39;t experienced that but i have had the driverside tierod replaced twice after they were installed. i was told that it was bent. i wish i could have looked at it after they replaced it to see the difference.
    i would suggest replacing your stock shocks too.
    i talked to the people at mcgaughy&#39;s and they told me i didn&#39;t need to.
    i did anyway because the stock shocks rode to soft and bouncy.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Don&#39;t use a pickle form to seperate the ball joints. Smack the casting with a heavy hammer from the side to release the ball joints from the taper. They also make a ball joint tool that is weighted and pushes on the balljoint unlike the pickle fork method.
    Jun 2006
    ya the reason i was worried about the tierods was because, i saw one of mcgaughys ads in truckin and it talked about if ur not using there gm approved spindles and going with just shackles and hangers,shocks from other companys your more likely to run into suspension problems down the road. can you tell any increasue in performance handeling with the 2-4?
    -4.3L
    custom air intake,
