Results 1 to 10 of 13
Thread: Thinking of changing cams
    I currently have a comp cam 212/218 cam. I'm thinking of changing to a vinci 220/224 551 lift. Do you all think it would be worth the change? My best time has been a 13.5@101 with a 1.9 60ft. in hot weather with the 212. Any one running this vinci cam? What do you all think, good idea, bad idea??
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    I like the 224/224 .581/.581 114 cam myself. You need about a 3200 stall but it's definitely a sweety with some 918 springs.
    Whats the difference between the 918 and ls6 springs. I already have the ls6 springs i think.(yellow springs right). Thats why i would like to go with this cam and the lift, but I don't know if it will be worth it , if i would just see little gains. I plan on adding a vig. 3200 stall also.
    Jan 2007
    <div class='quotetop'>QUOTE(graysilverado5.3 &#064; Jul 1 2007, 09&#58;42 AM) [snapback]98266[/snapback]</div>
    Whats the difference between the 918 and ls6 springs. I already have the ls6 springs i think.(yellow springs right). Thats why i would like to go with this cam and the lift, but I don&#39;t know if it will be worth it , if i would just see little gains. I plan on adding a vig. 3200 stall also.
    the 918s can sustain alot more beating, alot higher lift...the LS6 springs can sustain up to .570...you should get the 222/224 or the 220/220....me like 220/220
    12.82@103.82mph w/1.78 60ft
    TUNED BY DAN
    The reason I wanted a lower lift cam was so that I won&#39;t have to change the springs, haha
    918s will handle a max lift of about .600". The LS6 yellow springs would be collapsed way before then, .570 I believe it is.
    Mar 2005
    why not build your tranny first compadre, but good luck if you do swap cams.
    <div class='quotetop'>QUOTE(chev5.3 &#064; Jul 2 2007, 01&#58;47 PM) [snapback]98366[/snapback]</div>
    I&#39;m going to have to get a built tranny with stall first. Then i might wana change cams.
    hey guys i just got an offer for a 222/224 563 lift cam. Should I stick with the LS6 springs or go for 918&#39;s?
    I&#39;d go for 918 or LS6 springs as a minimum. Your stock springs won&#39;t handle the lift of .563. I prefer the 918s.
