I hate them, that is all.![]()
HAHA that was good! Yeah Snap Rings rate up there with flathead screws! LOL![]()
06 TrailBlazer SS LS2 4.10's
02 SC StepSide Factory Orange
Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
Snap rings = bad. Spiral locks = good.![]()
Slow, give us an update.
Gone, but not forgotten!
Yeah, how is the infamous build-up coming along? I can't wait to see it on the track.![]()
What's even better is when you finally snap it off, it shoots off the side, ricochets off every part in the engine bay and you loose it. And it is late at night when nothing is open so you can't go buy new ones. And you have to stop what you are doing cause you NEED that one snap ring. Ultimately, that is the reason for the holes in the wall in your garage...
The snap rings Im referring to arent the ones that hold the wrist pins in the pistons. I prefer those over spiral locks they are much easier to pop in. The snap rings I was dealing with are the ones that hold everything together in teh t-case. I was swapping the input gear out for a revised one that is cut bigger for the output shaft of the 80e and the damn snap rings really pissed me off. Im pretty much done with everything now, just gotta get my new trans crossmember built and get the motor back from West Coast CYlinder Head. Should be driving it in a month. The hold up is waiting on wiseco to make the pistons.
Yeah im pretty stoked to see it. I mean if it took you a little over a year to build it, then this bitch should seriously be able to lift off the ground and fly or something.
The snap rings inside a 4L60e suck! Those bad boys were meant to never be taken off.![]()
<div class='quotetop'>QUOTE(RedHeartbeat @ May 16 2007, 11:01 AM) [snapback]93661[/snapback]</div>Whoops, my bad. Yeah, we were talking about different ones. I haven't broken into my 60e yet, but I am sure I will be familiar with them once I am done. Can't wait for that...The snap rings inside a 4L60e suck! Those bad boys were meant to never be taken off.[/b]
