Just came into some money...what should I do? go from 6 to 10 pounds?? or get a 3000 yank??
2500HD 6.0 - K&N filter, TB bypass, Ported and Polished TB, no cats, SD Tune BY Nelson, 42# injectors, STS, T-67 .96 A/R, @5psi Walbro 255lph, Air to Water Intercooler, coolingmist kit @ 6ghp
CJ-7 - K&N, TBI 350, dana44 front locker, 9" ford rear spooled three link, 38.5" SS, bead locks,and tons more.
http://i44.photobucket.com/albums/f4.../100_04079.jpg http://i88.photobucket.com/albums/k1...eepcroped2.jpg
convertor! You can increase boost any time.
Heres some info my best 60 foot time is 2.0 went 14.4 @ 93
The stall is about $800
If I go to 10psi I would have to buy 60 pound injectors, wideband, 918 spring, and another fuel pump to run inline with my 255 intank pump (to be safe)
If wilde racing can cut 1.67 60s with a stock converter why upgrade? If 4hi with more boost you can bring that thing on up to 3K atleast. Wilde hit 3200 if I remember right. More boost and have fun.
<div class='quotetop'>QUOTE(1slow01z71 @ May 14 2007, 08:09 PM) [snapback]93415[/snapback]</div>He's also running 15lbs of boost. Plus, I don't think 2500HD is as rough on his truck as wilde. he still wants a safe daily driver.If wilde racing can cut 1.67 60s with a stock converter why upgrade? If 4hi with more boost you can bring that thing on up to 3K atleast. Wilde hit 3200 if I remember right. More boost and have fun.
I'd say 3000stall, if you don't tow heavy stuff and 10psi, with pump and injectors, not sure if that's over the budget or not.
good luck,
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
