I finished up the '99 LQ4 today in my blazer. It ran great the first few times I started it up. I let it warm up for at least 10 minutes and then revved it up a little. It sounded great, ran smooth and quiet. Then I took it out for a test drive and it was gutless. It almost immediately started running like it was running a cylinder or two short (vibration, no power, etc.). Then I slowly let it accelerate, and it would just hit a flat spot at about 3/4 throttle. I turned it around and took it back. By the time I got it back it was running even rougher, and when I'd give it a little bit of gas it'd knock (like a pinging).
I freaked, but now that I've given it some thought I think it must not be getting enough fuel, or fuel pressure. I did only have a gallon or two of gas in the tank, could this be a factor? (I don't think so)
I installed a tank with fuel pump from a 96+ tahoe (I think) that I found at a local wrecking yard. I'm starting to wonder if it might have been a 95 (it had the 95+ interior) and so not enough fuel pressure. I guess my next step is to check fuel pressure, but can someone tell me if I'm barking up the wrong tree?
Thanks!
I just went and got the AC/Delco EP381 pump. It looks exactly like the old one I have... It's rated pretty high. We'll see how it works. (crossing fingers)
