Results 1 to 10 of 15
Thread: Broke the turbo truck
    Dec 2003
    Newark, Tx.
    Well, another set back on our quest for 10's. We did a little tranny work and put it back in the Silverado SS.
    Went out and stalled it up to 7psi and POP, broke the output shaft in half.
    I think we are making a little power Now its time for the customer to spend $570 on a hardened shaft. We are giving the 4l65 one more shot before upgrading to the 4l80.
    Jun 2004
    george west texas
    hehehe....3 more broke 65e trannys and he will be right up there with me!!!!
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Sep 2006
    Coon Rapids, MN
    tell him he neeeeeeeds to upgrade to the 4l80.
    man that thing must be making a little power
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jan 2006
    HE SAID TOO MUCH POWER. SWEET!
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Jul 2005
    modesto, ca
    POWER is good
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Damn, you guys are tough on trucks. What next, driveshaft, rear axle, u-joints, lug bolts? Who's taking bets?
    Dec 2003
    Newark, Tx.
    I am a little worried about the driveshaft. All I can do is tell the customer.
    We have a Hummer that is getting more motor than the Silverado SS and he is getting a turbo. We are skipping the 65 and going straight to the 80.
    Yeah, I remember talking about the Hummer. I need it's engine to swap out the 4.8L in the 07.
    Bloomingdale Illinois
    <div class='quotetop'>QUOTE(trtturbo &#064; May 7 2007, 06&#58;02 PM) [snapback]92607[/snapback]</div>
    Well, another set back on our quest for 10&#39;s. We did a little tranny work and put it back in the Silverado SS.
    I think we are making a little power Now its time for the customer to spend &#036;570 on a hardened shaft. We are giving the 4l65 one more shot before upgrading to the 4l80.
    I hope for &#036;570 it is a billet output shaft. Unfortunately the input sprag or drum will be the next thing you explode. Sounds like you are (forgive me for saying this) making to much power. Vince
    Mar 2007
    There&#39;s no such thing as "Too Much" power... Why not push this tranny as far as it will go first, for bragging rights, then upgrade to the 4l80... Not many 4l65 tranny&#39;s in a 6,000 lb. truck doing AWD lunches at 10 lbs. of boost running 10&#39;s in the 1/4... That would be one hell of an accomplishment if you ask me....But, who knows, anything could happen at this point....
    2004 SSS.. Force Fed 408.. STS @ 10psi.. Best 1/8th was a 7.35 @ 91mph and a 1.69 60&#39; at Kennedale.. All made possible by TRT Performance, Arlington TX..
