Results 1 to 10 of 12
Thread: Eaton LSD wanted
    College Station, TX
    Looking for a Eaton LSD for my truck.....especially before the 6 liter goes in....and I want the engine in, in about a month and a half.....All I have left to do is put my 373s in and the LSD....Anyone know where to find these for a reallllly good price...Looking to pay around 400-..450$ preferably...Do you guys know the model numbers or which one would be right for me? I only found some at summit and they wanted 500$ ...and ebay only had ones for like 73 chevys and older
    Let me know!
    Aggie
    sprayed99 Guest
    I know where you can get the detroit true trac with bearings races and the shim kit for around 450 shipped
    College Station, TX
    Will those work for my setup?
    Where can I get em?
    http://www.inmotionperf.com/cart/index.php...t&catId=104
    ^^good or can I find better?^^
    College Station, TX
    So Will I need the other stuff you got in your purchase Gator?
    What all will I need to go along with the LSD ?
    Bearings?
    Shim Kits?
    With a ring and pinion and LSD you need to buy 2 quarts of lube, rear cover gasket or silicone sealer, new axle end seals, pinion seal and the install set that should have 2 carrier bearings and races, 2 pinion bearings and races, spacers to set the backlash on the pinion and carrier bearings, a new nut, new bolts for the ring and pinion and a new crush sleeve. It should come with contact paste to check the gear tooth contact pattern.
    College Station, TX
    Thats what I needed right there! Thanks!!!
    Jan 2005
    Humble/Houston TX
    randys ring and pinion quoted me 402.64 for a detroit tru-trac. they also quoted me 107.49 for the yukon master install kit which should include everything mentioned above and more
    old mod list: H/C/I/N/E/G 408
    College Station, TX
    How do I get the install kit? website? Im just gonna go with the eaton..I got it for a really really cheap price
    Jan 2005
    Humble/Houston TX
    call up randys ring and pinion and tell them what you want. search around for better prices first though and they should match. i only checked with them cuz their record is spotless as far as i know.
    College Station, TX
    <div class='quotetop'>QUOTE(TXsilverado &#064; May 2 2007, 12&#58;50 AM) [snapback]92040[/snapback]</div>
    Number?
    Ill call tommarow and get some quotes
