Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 54
Thread: sucky times again
    well i just got back from the track here in edinburg and did 3 passes, the 1st one i ran a 60ft of 1.91, 330@5.62, 1/8th@8.73@76.24mph and a 13.84@96.59mph, this was stalling @ 1100rpm's, the 2nd pass i ran a 60ft@1.98, 330@5.73, 1/8th@8.87@75.67mph, and a 14.05@94.69, and this was stalling @1900rpm's, then on the final pass did a 60ft@1.94, 330@5.63, 1/8th@8.72@78.04mph and a 13.75@97.96mph, and this was stalling almost idling@900-1000rpm's, it feels like and sounds that my truck luggs out 1/2way before getting to the 1/8mile, telling me that my stall is locking to soon and not at WOT and losing top end,
    Whoop Ass Racing
    Radix W/Intercooler
    E.T is a 12.79@105mph
    http://i25.photobucket.com/albums/c5...sracer/sig.jpg
    Sorry man, the weather kinda sucked today no? I guess you were hitting better times with the tb stall huh..
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Unlock the convertor at WOT. There's two ways of going that. One with the tune and the other with a toggle switch to break the electronic power circuit to the TCC. You might get an SES code with the switch, though.
    was getting better 60fts' with tbstall but in cold weather, though, and also what would be the best speed to lockup the verter, do ya'll think around 110-115mph would be fine, what do yall think. and would i need to go see allen for the lockup tune or can i just call him and tell him to unlock it at WOT.
    Whoop Ass Racing
    Radix W/Intercooler
    That or splice the switch into the brown/black wire from the Red PCM connector pin 42 or down on the transmission end it's terminal T. That is the grounding circuit for the TCC. You could hook two switches to it, one to break the circuit so that it doesn't lock up and another one to ground it and manually lock the TCC when you're on the dyno and want the power locked to the rollers.
    well here's a bit of info, of my new setup and old setup
    1). My setup now is the radix w/intercooler,3.1pulley,(9psi),18*'s of timing, edelbrock shorties headers, 42lb injectors,80mmtb, 4:10's w/eaton posi, electric fans, sdtune, meth injection,transgo reprogramming shift kit,4l60e built tranny, PI Vig 2600 triple disc,with 28x15x10.5inch slicks(hoosiers drag's)1/4mile ET 13.75@96mph
    2). when i ran the 12.79@105mph, i had of course the raidx w/intercooler,2.75pulley,(10psi) 12*'s of timing, edelbrock shortie headers, 42lb injectors, 80mmtb, granatelli Maf, 4:10's w G80unit, electric fans, nelson performance tune(not sdtune) transgo reprogramming shift kit, 4l60e built tranny, and stock stall, with 26x16x10.5inch slicks(et streets)
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Apr 28 2007, 09&#58;07 AM) [snapback]91689[/snapback]</div>
    That or splice the switch into the brown/black wire from the Red PCM connector pin 42 or down on the transmission end it&#39;s terminal T. That is the grounding circuit for the TCC. You could hook two switches to it, one to break the circuit so that it doesn&#39;t lock up and another one to ground it and manually lock the TCC when you&#39;re on the dyno and want the power locked to the rollers.
    any pics of it being done bro, if i go this route it would save me time to head down to san antonio, and which in other and can just do it here at home,
    Whoop Ass Racing
    Radix W/Intercooler
    Are you sure you&#39;re not getting some detonation? Maybe too much meth? Going to the taller tire is kind of like switching to 3.73 gears from the 4.10s you had before. The tire by itself can slow you down.
    Nope, no pics available. When I go to the dyno they always have problems keeping the convertor locked so I dug out the ATSG service manual and researched this extensively. You can just pull the fuse that powers the TCC to see if that does what you want it to do. I&#39;d research and see if that fuse powers anything else before pulling it for the test.
    well for meth im just using washerfluid to cool the iat&#39;s thats it, and well on the slicks i tried both 28&#39;s and 26&#39;s both drag&#39;s and did better with the 28&#39;s,
    Whoop Ass Racing
    Radix W/Intercooler
    We seem to have a rash of guys running worse this spring than last year. What&#39;s up with that?
    but i think it relys on the tc cuz had the tbstall for a while was trapping low speeds, then put on the stock one again and gained it all back, then put the pi vig 2600, supossably the best stall, and still trapping low speeds, so i think it relies on the TC lockup of something,
    Whoop Ass Racing
    Radix W/Intercooler
