Well...I got the call today from the wife. She was backing the burb out of the garage and when she put it in gear it died. She started it up again and when she put it in gear again the rpms dropped to about 300 and it almost died. She started it again and was able to get out of the alley but it died again at the stop sign. One thing she noticed was that the speedo was not registering the right speed....ie. when slowing down it would show 17-20mph when she was going maybe 5mph but the speedo would eventually drop to 0mph. My first thought is it is maybe the VSS or TPS since I have heard that those will occasionally cause these type of issues.
I'm going to check a few things when I get home but was curious if there was anything else that may be causing it. Fuel filter should be good as should fuel since we fill up at the same place and I haven't has any fuel issues. Anyone got any ideas about what I can check? TIA
'02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
