My buddy swapped an 04 LQ4 into his 00 Sierra about three weeks ago. The last few days, it has began to misfire. We assumed its either an injector, coil pack, spark plug or wire because its only two cylinders misfiring. after swapping coils, plugs, wires, and the injectors, the truck still continues to misfire. note that the misfire is only on cylinder 1 and 5. he had the truck hooked up to a machine and none of the other cylinders were misfiring. the number 1 cylinder fluctuated from 5 misfires to 16 misfires. what would you suggest he do next? is it a possibility that its a tuning problem since he's replaced the 'mechanical' parts? thanks in advance!
