Results 1 to 4 of 4
Thread: Redheartbeat
    May 2006
    Waco TX
    I was going through some of the used parts here at the shop and I have a new efan off a ford crown victoria police car. The fan is 18 inches in diameter and the shroud is 26 inches. I hooked it up to the battery charger and it put out a ton of air. Would this be enought to cool me truck or no?
    I'm not Red, but a guy I knew had a fan like those on a 97 chevy truck and he said it worked fine. I was thinking of putting one of those in my truck cuz he gave me one, but to be safe i went with an impala efan.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    It should be fine. Be sure you seal off the fan housing to the radiator so that it has to pull 100% of it's source air through the fins. I ran LS1 fans on my 92's 34 radiator and it worked fine. The 2005 Silverados work a lot better though.
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Apr 11 2007, 11&#58;30 AM) [snapback]89562[/snapback]</div>
    It should be fine. Be sure you seal off the fan housing to the radiator so that it has to pull 100% of it&#39;s source air through the fins. I ran LS1 fans on my 92&#39;s 34 radiator and it worked fine. The 2005 Silverados work a lot better though.
    Yeah, I&#39;ve heard that the 05 efans work the best also....
