Results 1 to 8 of 8
Thread: Anybody running AMSOIL Synthetic ATF
    Aug 2005
    Spring, Texas
    I am going to be installing my new TCI3000 and was wanting to put a real good tranny Fluid back in. Does anyone have experience with Amsoil Synthetic ATF?
    I am very pleased with the Amsoil Motor Oils, but never used the ATF.
    Later
    Bulldog
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    For performance applications I always hear not to use synthetics due to the fact that they are too slippery. Normal dinosaur fluids are best for IMO, you'll need the friction for the clutches.
    Mar 2006
    Mesquite
    2nd that...
    Aug 2005
    Spring, Texas
    Thats kind of what I figured. That stuff is expensive, their website shows it to be $108.00 for 12 quarts.
    I'll probably just go the old route with some lubegard additive!
    Thanks
    Mar 2004
    NY
    I work in a parts store and we just got in valvoline dexron VI full synthetic. Label says in some 2006 and all 2007 gm cars trucks. Also says compatable with dexron III.
    2015 GMC Sierra RCSB Z71 5.3
    Oct 2007
    Yes I have Amsoil everywhere does a good job.
    Jan 2006
    Read the manual on the converter. Yank recommends regular trans fluid.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Slimsilverado Guest
    HMMMMMMMMMM i have had Mobil 1 trans fluid in mine since birth and it has done great but its all stock 60E
