Results 1 to 10 of 18
Thread: killed a turbo truck
    Dec 2003
    Newark, Tx.
    We were putting a few miles on a truck at the customers request and I just happened to be leaving the shop in my '92. Wasnt really planning on anything, but eariler, Dustin was giving me hell about it being faster than mine.
    Well, it wasnt. We did several little runs; one from about 20 to 80 and the result was the same; I would pull him w/o much of a problem. I let him stall into boost (6psi) once, and I still pulled him while spinning.
    Now for the part that makes it less impressive. It was a very low compression (8.0:1) 370 in a 1500HD crew cab only running 6psi. My truck is about 1600lbs lighter.
    If I had that motor in my truck, I'd run 18psi with the low compression.
    It was nice to have something to run though.
    <div class='quotetop'>QUOTE(trtturbo &#064; Jan 25 2007, 08&#58;53 PM) [snapback]81252[/snapback]</div>
    We were putting a few miles on a truck at the customers request and I just happened to be leaving the shop in my &#39;92. Wasnt really planning on anything, but eariler, Dustin was giving me hell about it being faster than mine.
    If I had that motor in my truck, I&#39;d run 18psi with the low compression.
    You should get a video of it next time
    Jun 2004
    george west texas
    dude...he needs to UP tha boost bad&#33;&#33;&#33;&#33;
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Dec 2003
    Newark, Tx.
    He pulls 13,000lbs with it and wanted that way.
    Jun 2004
    george west texas
    oh...thats another story then...never mind.......
    May 2005
    with his compression so low and low on boost, its more like you beat an almost stock truck
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
    Dec 2003
    Newark, Tx.
    thats why I said "now for the part that makes it less impressive".
    Dont get me wrong, the turbo is pretty quick for the size. The truck runs less than 9.0 in the 1/8th.
    We are shortly pulling the motor out of my truck to do the turbo and forged motor, but I would like to see what it will do at least once.
    It would be so much better without the 3:08s, but it is still quick.
    Jan 2006
    SWEET&#33;
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Yeah, get some numbers at Kennedale before you pull your current 5.3L apart for the STS buildup.
    Ft. Worth, Tx
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jan 26 2007, 07&#58;21 AM) [snapback]81294[/snapback]</div>
    I second that motion&#33;
    90 GMC RCSB Forged 370 and Built 4L80E from the VHO going in slowly but surely
    89 fox body notch... No motor or tranny mod but a narrowed 9" w/ 35 spline axles and a spool!!
    2011 Tundra CM 4x4...
