Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 67
Thread: truck wont start
    When I was researching the efan stuff I found out the 99-2002 had different pinouts than the 2003+.
    Very few differences. THe electric fan vs. the climate control door control is one and then the TAC module/TB control wiring. Most of the others are the same.
    yellow is pin 59 blue wich says unused
    brwn/wht is pin 46 green mil control?
    wht is pin 10 green engine speed signal
    blue is blue pin 17 transmission fluid pressure switch signal b
    grenn/wht is green oin 50 vss signal
    purple is blue pin 33 tcc brake switch signal
    White would be your tach signal. Green/white is speedometer. Brown/white would be a ground for a lightbulb to illuminate a malfunction indicator lamp.
    Are those wires broken from the PCM as well? If so, you've probably found the problem. If not...they go somewhere else.
    you meen removed from the pcm connector? im not quite following you.
    i found an 04 pin out the yellow comes ups class 2 serial data circuit number 710 the others stay the same are any of these needed to start
    I mean look for the other end of the wires at the PCM. The data line may be one of the most important wire there is.
    o yah there hooked up there where should the unused end go?
    Kentucky
    for the electric fans make sure you hook it to the light green or may have white stripe and not the dark green. This will cause the DBW not to work.
    1996 GMC extended cab, 2003 5.3/auto
