Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 51
Thread: LS2 vs. LQ4
    Alaska
    *Chuckles* I know I shouldn't but I cant help myself..........speaking as a machinist and general smart arse the reason all Fuel class engines are all based on alum like T-6 and others instead of "good ole iron" is tensile to weight ratios while you could obviously engineer an iron block as strong or stronger then the current alum why in the hell would you? Alum blocks can and do make over 4k hp and are dead reliable at 60% less weight the failures sighted in alum Lsx's as far as I can tell have mostly been design/build failures not material failures hence the changes the CR5 team made along the way, to their blocks.anyway from a material view of course alloy iron has higher tensile properties then say t-6, however the tensile stress/es encountered in even a maximum effort road race engine are well with in range of duty for modern alum mixes, obviously for the success/es in all form of motorsports using various high output alum black based engines
    As for the original topic question..........i dunno......
    1990 K5 Blazer (current project) Already done: 4" lift, Skyjacker Springs on front, DIY4x4 flip shackles on rear 1" ORD body lift with Energy Suspension body bushings.Auburn ECTED Lockers front and rear in 8.5's spinning 4.11's, Yukon Axles all around T&A girdles, JB Conversion SYE NP241, Almost done: Stereo; pair Kicker 3.5's in dash, pair Kicker SS65.2's in custom 'glass kicks four Kicker SSMB8's in 'glass boxes in rear pillars, two Kicker L7's 15" Alpine iDA-x0001, two EQl's, two 25toLife Punch 45's, 75's & one 150......To Be Done:LS6 & 80e swap DIY4x4 bumpers, Warn 9.5si winch, 150 series Mattrack tracks on all for corners and just for giggles 250hp wet shot.
    ESTHERWOOD,LA
    I Have A 2007 Silverado With The 5.3 Can You Tell What The Proper Name Is For The Motor Like Lq4 Or Lq9
    8th vin digit from the left, what is it ?
    Oct 2007
    connecticut
    Quote Originally Posted by black truck View Post
    dont quote me but i believe its a LM7 or L59, guys if im wrong, please dont kill me!!!
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Dec 2004
    San Antonio, TX Area
    So what is the price of an LS1 complete with trans, harness, and accessories?
    LQ4, LQ9, LS2. Thanks Art...
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Jan 2007
    Quote Originally Posted by murdered_outgmc View Post
    I never hear of anyone swapping to an LS2. Why is that?
    sure people have.. well actually I've only heard of one.. a buddy of mine over here swapped a LS2 into his 07 Chevy NNBS rcsb wen he barely had it for maybe 2months... His best time up to date is a 12.2 fullly bolt on, cam, QC converter, 4.10s, Tiburon tune... He got his LS2 from an SSR.
    12.82@103.82mph w/1.78 60ft
    TUNED BY DAN
    LOL I hate to stir up old stuff, but i've been gone for a bit and didn't know this thread was still up and running.... I guess the consensus is that im out of my mind and such and thats ok with me
    But I will point out a couple threads since I got the time this morning.
    Aluminum vs, Cast Iron Block - Page 4 - Club Cobra
    Those are some ford guys talking back and forth a bit....
    http://www.competitiveproduction.com...o=3&issue_no=2
    Here's a general look at iron, and the cars they are used in today. Inlcuding NASCAR....which i would think aluminum would be better for since its lighter and just as strong and everything, but i don't know. this is just for your reading enjoyment though so don't get all bent out of shape. Regaurdless of what you think or say, Iron is still stronger lol.
    aluminum blocks - Car Forums and Automotive Chat
    I can go alll day on this stuff really....but like i said, im not here to start a war, but I'll be damned if you think im an idiot for making my claim....
    Chevy LS1 Engine Block Basics - Hot Rod Magazine
    I guess i'll call it quits for now....when you feel the need to down me again cause of how stupid my comment is then let me know...I'll check back on this thread in a couple dayz and you can talk your smack and ill back my comment up again with more proof like ive done this entire thread.
    I especially like this comment made by hotrod magazine.
    "So what does this mean to the average enthusiast? Well, if you're modifying a '98 Camaro with a set of CNC heads, a cam, and some headers for a 520hp package, your stock aluminum block should work just fine. But if you're bolting a big centrifugal supercharger on your C5 Vette with visions of a streetable 700 hp, you should make some modifications to the block. In fact, if you want factory durability, you should be considering taking the 88-pound hit to swap in the iron block."
    But these guys are probably about as dumb as me. Since Quik, AK5, and a couple others seem to know everything about aluminum vrs iron. Oh well win some lose some i guess.
    Later Gents
    Somebody kicked the dead dog again
    Feb 2008
    North NJ
    Exclamation Dear God!!
    This was some funny ****! You guys made my lunch break!!
    Although I merely stumbled upon this Wrestlemania thread looking for info on doing an LS2 swap into a 'rado, (and I did find it between the stupid comments) I'm thinking I'll probably rebuild my LS6 and save the LS2 for something like an 'old musclecar!
    ahhh...good times!
    '07 TBSS AWD 6L90E Conversion and '07 TB "RS" 4WD 6L80E Conversion!!
    www.TBMsport.com
    True Blue Motorsport
