Need input on NEW MOTOR!
O.K. guys, I am going the 370 from Texas Speed
. Eagle crank, Scat H beams, Diamond pistons. 9 to 1 is the desired compression.
I will be using the L92 heads, and the GMPP intake with an Elbow and probably a 90mmTB.
The rest of my mods are in my sig.
I want to get up to at least 20-25 psi on the high setting.
Now Do I keep the 220/220 .581/.581 on a 115 cam or go with a different grind?
Any opinions are welcome on the cam or whole setup.
Thanks,
Jamest
12 Sec. Club! SOLD
SOLD***
