Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: Need input on NEW MOTOR!
  1. #11
    Jan 2006
    That's what I was thinking. everywhere I was looking , they had a similar cam setup.
    Quote Originally Posted by thunder550 View Post
    That's probably a good cam. It has a wide LSA so there will be very little overlap. I'm running a 220/222-580/580-114 in my 408 and I love it. Idles like stock and has good vacuum, which is a must for me when towing. I think that cam will probably do very well in that engine.
    For driveability, you may want to consider bringing that CR up a little bit. 9.0 sounds a little low...I personally wouldn't go below about 9.2 or 9.3 just so you have good running quality out of boost. At 25 psi I'm sure you're planning on running race fuel and methanol anyway, so the extra couple of tenths for compression shouldn't make a whole lot of difference. Just my opinion.
    12 Sec. Club! SOLD
    SOLD***
  2. #12
    Feb 2005
    Austin, Texas
    Keep the cam, its not nearly as important when the air is being crammed into the motor, and that cam will give you good NA performance so Id stick with it, sounds like a nice setup, we need to have a track day some time soon.
  3. #13
    College Station, TX
    I call dibs on your 6.0
  4. #14
    Quote Originally Posted by Jamest View Post
    O.K. guys, I am going the 370 from ...
    Any opinions are welcome on the cam or whole setup.
    Thanks,
    Jamest
    Ok, James, with all the mods we talked about and taking in consideration the truck is a daily driver with occasional truck use, here are the cam specs.
    224/232 - .568/.575 - 113+2
  5. #15
    Jan 2006
    Sweet! Isn't the 113 a little low for a turbo can? Or is that what the +2 is for? I hope she runs like a BAT OUT OF HELL!
    Jamest
    12 Sec. Club! SOLD
    SOLD***
  6. #16
    College Station, TX
    Hey wait r u using your existing 6.0? or selling it as a longblock?
  7. #17
    Jan 2006
    I promised someone the motor a long time ago.
    Sorry.
    It will go to Allen's welder at Nelson Performance.
    I can't break a promise.
    Quote Originally Posted by Aggie View Post
    12 Sec. Club! SOLD
    SOLD***
  8. #18
    Dec 2003
    Newark, Tx.
    the "+2" is a little advance ground in the cam. It will make it a little more responsive in lower rpms
  9. #19
    Dec 2003
    Newark, Tx.
    why the Scat rods and not the Eagle?
    just curious.
  10. #20
    Jan 2006
    I can go Eagle. They quoted me a price with the Scats. I have not ordered it yet. I am assuming Eagle's are better?
    What are your suggestions?
    Quote Originally Posted by trtturbo View Post
    just curious.
    12 Sec. Club! SOLD
    SOLD***
