How many miles?
Figure the pinion bearing on my Blazer has made roughly 1,088,000 "miles" of revolution. How 'bout yours?
Gear ratio multiplied by odometer. Remember to factor gear ratio changes if applicable. No, it's no accurate as burn outs and running one in the air change the factor...as does locker vs. non-locker, etc. Also remember that if you have run non-stock tires without speedo correction your odometer is off too....just factor the % difference in tire size or gear ratio and apply that % +/- to the odometer for the time it was incorrect. Mine is easy since it's stock ratio with the 3rd set of OEM copy tire.
Still a fun game/guess.
- You may not post replies
- You may not edit your posts
