Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: Level 5 4L65e
    College Station, TX
    AWD requires the output shaft be changed and the adapter put in place of the tail housing.
    Is it worth getting this tranny then? If so how much more would I need to spend to get it to work on my setup? Im sure its not worth going through the hassle of swapping output shafts correct considering the built tranny one is stronger, well if it is...
    Not sure what the shaft costs. You could get a housing from a trans shop off a core or from a wrecking yard. I wouldn't recommend a used shaft though. You'll also have to pay someone to gut it. May cost $400? Not sure. Allen, feel free to delete this post is it messes up your for sale post.
    College Station, TX
    Alrighty thanks for the info nathan!
    Bahh this blows.....#$%#$%$#%#!!!
    Jun 2007
    output shaft is different in 2wd/4wd .if you still bought it and replaced it ,make sure you replace it with a billet output shaft ,trust me,it was about 4-500 bucks i believe.although you could sell the 1 in it for 2wd to someone,i would say it probly has a 2wd billet shaft in it.good luck.I went through 3-4 output shafts b4 i installed a billet 1,knock on wood no issues with the billet shaft.good luck
    Jan 2006
    He has the 4wd shaft in his ruck already? Won't that one work?
    Jamest
    Quote Originally Posted by Ramsey View Post
    12 Sec. Club! SOLD
    SOLD***
    Yeah, he can pay someone to tear them both down and swap the output shafts. It's not too hard but will cost a bit to pay someone to do it. They've got to buy pan, valve body seperator plate gaskets, front pump gasket and then labor.
    That trans being an FLT trans I would only want FLT to swap the shafts. Some one else gutting it would void FLTs warrenty.
    Depends on if FLT is the one that refreshed it or not. Allen could have it swapped out by the builder, otherwise. The FLT only has a 6 month warranty, right?
    Spring, Texas
    Yep, only 6 months. After that you're on your own no matter what....ask me how I know
    College Station, TX
    I mean Im still down to buy it, I just wish the new parts and stuff would be the same price if not 100$ more that Im paying now for it
