haha I know what TPIR is.. its not a good show anymore with drew carrey..
James why wouldnt your numbers be higher then the previous ones?
12 Sec. Club! SOLD
SOLD***
6.0L with a T-76 running 10psi should bump 575-600rwhp mark even with an automatic.
btw: those A1000 are LOUD !!!!!
You might want to consider running dual external Walbro. instead.
If you are hung up on using the A1000, look into the Aeromotive Eliminator pump instead.
It is same size and shape as A1000, but flows 20% more and has bigger inlet and outlet fittings.
I run one on my Stang, nice pump.
If you ever want to turn up the boost the A1000 is already maxed out on a forced induction
engine at just over 600rwhp.
2002 Tahoe 4.8 - soon to be turbo'd - SOLD
1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
2012 Raptor - 497rwhp at 10psi
If you aint breaking - you aint going fast enough
my a1000 is fine over 700 rwhp. they claim its good for 1k hp forced induction. I plan to see, if not i will just run 2 since i have a few of them...lol...
Aeromotive Inc. - High-Performance Fuel Systems & Fuel Pumps
single digit street truck
for build info
12 Sec. Club! SOLD
SOLD***
I Highly doubt that, i've run the A1000 up past 850-900whp numerous times and never had one flinch yet. But yes they are fairly loud. There are quite a few nice pumps out there now
**Edit**
with twin walboro 255's or bosche 044's you shouldnt be running out of fuel yet, what injectors/lines/pressure are you running and what kind of fuel (E85/98, race gas or just regular 'pump'?) they should flow fairly close to what the A1000 flows
His setup consists of dual walbros, but specifically, one in the tank and one inline.
Unfortunately, when running two pumps like that, you don't double your capacity, you're still stuck with one inline pump.
I've also tried two walbros in the tank, with a Y fitting and it's just slightly better than the other config.
Of course this was on a procharged 6L with 15psi.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Nelson Performance
NP on Facebook
Youtube Channel
