Funny you should say that I jsut recently had a buddy bring one of those kind of engines over to the shop it was a 5.3 and oil sludge was built up all the way past the first coil of the springs.Originally posted by docone882000+Jan 12 2006, 06:00 PM--><div class='quotetop'>QUOTE(docone882000 @ Jan 12 2006, 06:00 PM)</div><!--QuoteBegin-Tim ZI have pulled apart a few engines no one took care of. When there is so much build up of oil it will not let you remove the push rods something is wrong. You should not have to use pliers to pull them out. The lifters would not even slide out. You could not even see them. The valley was like a dryed up tar pit.@Jan 12 2006, 03:07 PM
mobile 1 in everthing i drive, do it my self .every 3000#! oil is the lifeblood of your engine , change it often!( i might be a little anal bout that)![]()
David [/b]
