View Poll Results: Which do you perfer?
Voters
19. You may not vote on this poll
  • Dealership
    1 5.26%
  • Lube joints
    4 21.05%
  • Do them yourself
    14 73.68%
Results 1 to 10 of 23
Thread: Oil changes
    Jan 2006
    San Antonio
    How do you perfer your oil changes done? What type of oil do you perfer?
    David
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    i like to do them myself. i usually use royal purple 10w30. i like to make sure everything is clean underneath too. i usually check a few things too.
    Aug 2004
    Magnolia, TX
    went to Wal-mart for the first oil change on the lil chorizo....mobile 1
    May 2004
    Mobile 1 at my buddies Pennzoil Shop. I can't change the oil and dispose of it as cheap as he can. I would rather do it myself though.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    i used to work at this valvoline oil exchange for two years. so i just buy the oil and they give me a discount and what not. and i just dispose of my oil at this place for free. its actually right next door to my house, the neighbors yard... nah i just take it back to the place where i worked
    Nov 2005
    ohio
    mobile 1 in everthing i drive, do it my self .every 3000#! oil is the lifeblood of your engine , change it often!( i might be a little anal bout that)
    Jan 2006
    San Antonio
    I have pulled apart a few engines no one took care of. When there is so much build up of oil it will not let you remove the push rods something is wrong. You should not have to use pliers to pull them out. The lifters would not even slide out. You could not even see them. The valley was like a dryed up tar pit.
    David
    EL JEFE
    ROUGHNECK
    Nov 2005
    ohio
    Originally posted by docone882000+Jan 12 2006, 06:00 PM--><div class='quotetop'>QUOTE(docone882000 &#064; Jan 12 2006, 06:00 PM)</div>
    <!--QuoteBegin-Tim Z
    mobile 1 in everthing i drive, do it my self .every 3000#&#33; oil is the lifeblood of your engine , change it often&#33;( i might be a little anal bout that)
    David [/b]
    i thought those were QUAKER STATE engines&#33;&#33;
    Jan 2006
    San Antonio
    That is funny. Quaker state. Sorry just not my first choice. But I will not knock a guy if it has been good for them.
    David
    EL JEFE
    ROUGHNECK
    Jun 2005
    I used to do it my self but now there is too much to do and I get a free detail on the Nalgona too. But she is treated to Mobil 1 every 3k to 3500.
    01,Z71 Victory Red, sportside,5.3L, Flowmaster 40&#39;s, K&N Drop In, Airaid MIT Tube, TB bypass, Nelson Performance Hot Tune. Velocity Stack waste of money.
    Working to run with the BIG DOGS, tired of the porch. STS or LQ9 in the future.
    http://i56.photobucket.com/albums/g1...1/DSC02262.jpg
