Results 11 to 20 of 21
Thread: what is this called?
  1. #11
    Apr 2006
    Bellevue, Nebraska
    Quote Originally Posted by RPM Graphics View Post
    i'm not swapping rails, just cleaning this one up. it's been sitting for a while.
    what do you mean the vette filter doesn't work?
    Looks like the FPR. Had one on my '99 sierra. Has a little mesh disc inside that can be replaced for about $7.
  2. #12
    It does work for everyone else in the world.
  3. #13
    Pittsburgh, PA
    In some cases the vette filter works in other cases it doesn't
    You need to buy the gm filter. Spending 20 dollars on the cheap one doesn't work right
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  4. #14
    i bought my vette filter kit from Speedway Motors, hope it works.
  5. #15
    The only reason it wouldnt work is if you hook it up wrong. I have never seen one not work properly. I like the wix 33737.
  6. #16
    Midwest's truck defies all physics as well as all natural laws.
  7. #17
    Nov 2011
    Arlington, Tx
    We use the vette filter on the majority of the swaps we do, just make sure you get the wix filter and not the house brand Oreillys filter. Wix brand actually regulates it at a steady psi. The cheaper ones have been known to jump around in psi. And that looks like a ls1 fuel rail, if it is then its a dampner.
  8. #18
    Quote Originally Posted by LS3CC View Post
    Mine was the Wix.. tried two different ones.. it would hold pressure too high, and then it failed and held zero pressure. put in an aeromotive FPR and works perfect now.
    Mine failed as i was using the vetter filter on my TBSS fuel rails, which are returnless, and my 03 truck is return style.
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
  9. #19
    I have seen the results of installing the fuel filter backwards and that is exactly the same results they got. The 3/8 side of the dual fitting side is the input line of the filter and the 5/16 fitting is the return line back to the tank. The single fitting side goes to the fuel rail. Your setup is no different than anyone else's that is working properly. Many have thought the 5/16 side was for the fuel pump side only to find excessive fuel pressure at the rail.
  10. #20
    Nov 2011
    Arlington, Tx
    Exactly. ALOT of people install them backwards
