Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 42
Thread: Need help with PowerGlide/Converter NO GEARS
  1. #11
    San Antonio, TX
    If the linkage was good then your converter may have just blown the stator.
    DAMN, the linkage appears to be functioning and hooked up, can't see anything that doesn't move when the lever is moved.
    So I think all that is good.
    CIRCLE D, DO I NEED A CONVERTER HAHAH?
    btw, first time I pulled the pan since it was built, glitter and material was very minimal, just normal stuff in the pan. Nice and red color too.
    What can i check next? If it's the converter, that's bs, very low miles, very expensive and now possibly worthless!
  2. #12
    maybe casey can shine some light on the subject since he's done so many powerglides.
  3. #13
    Round Rock, TX
    Is your drive shaft hooked back up?
  4. #14
    LOL, after the fluid question I was afraid to ask that one.
  5. #15
    I guess I should ask if the linkage is hooked up the the gear selector cable. lol
  6. #16
    San Antonio, TX
    Quote Originally Posted by DBRODS View Post
    Darn, no it wasn't, thanks that fixed it
    Casey, you got anything to add?
    One miraculous thing that happened tonight, I tested pressure, drained the fluid, pulled the pan, and didn't make any mess or one drop on the floor , hahah.
    thanks in advance for any comments guys,
    allen
  7. #17
    I was thinking your low on drive-shaft fluid. If not try this out, it might help you!
    Power-glide Help
  8. #18
    casey23 Guest
    If its pushing fluid the pump gears are not broken .. You test this you install fluid in the trans and allow it to settle.. look at the level on the dipstick and then start the truck... if it does not drop at all then something is very wrong.. Also.. it could be a broken input shaft.. that would allow the fluid drop when its running because the "lugs" on the converter make the pressure.. But the converter itself is doing nothing... sounds like you have done the visual stuff... check the fluid and of course the shifter/linkage to make sure as you move the shifter its moving the linkage.. after that it needs to come back out.. but its a simple fix... and YES the imput shaft will pull out by hand.. nothing special... maybe it stripped the splines
  9. #19
    Oct 2008
    Sounds like most of the questions have been asked and answered. I would like to know the outcome on the input shaft. Give me a call when you get a chance to go over the details.
    723-895-8834
    Chris
    Visit us on Facebook
    Please fill out my Ask Chris form for converter recommendations.
    http://www.circledspecialties.com
  10. #20
    San Antonio, TX
    Quote Originally Posted by casey23 View Post
    It's go pressure, verified that. Oil was full.
    The input shaft came out fine and looked good. NO damage to it. Pulled out and went in normally. Locked into place too.
    Any other ideas? I'll pull it again today.
