Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: slightly bigger tires=super bad gas mileage?
  1. #11
    I go from 24 average to 18 average switching to my winter tires and rims, 18 pounds difference at each corner. I dunno bout you but here the winter gas has more ethanol in it too, so thats a loss.
    Mar 2007
    Austin,TX
    Like many have said, it's not just the issue of larger tires.
    It is likely a cause of many different factors. Here are some possible contributing factors:
    -Decrease in temperature. The colder it gets, the longer it takes for the engine to warm up causing more fuel to be burned
    -Increase in tire size and rotating mass. Likely caused about a 1 mpg loss
    -Bad gas. Did you fill up at walmart or other cheap gas station?
    -driving habits. You may drive the same roads to work or school, but if there is traffic, or you were in a hurry, it could have a big affect on gas mileage.
    How long did you log your gas mileage? If it was less than 2-300 miles then I wouldn't say that it it's a valid decrease just yet.
  3. #13
    Quote Originally Posted by Madd Maxx View Post
    This will cause a noticeable decrease in mpg, especially if your mileage is based on around-town driving and not highway miles. Colder air requires richer fuel mixtures, and it takes longer before the engine achieves closed-loop mode, where the O2 sensor controls the air/fuel ratio. Depending on your type of driving , 4+ mpg decrease is not unreasonable.
    Well said Sir.
  4. #14
    May 2010
    Dallas Texas
    When I switched over from factory sized tires (cant remember what size exactly) to some really hevy BFG Mud Terrains 287/75/16 and they weigh a ton my mileage went from 19 to about 15 on the highway so I feel ya man... especially since premium is hoovering around 4 bucks
    2000 GMC Sierra Z71 6.0 LQ9, Mahle Forged Flatops, Comp 208/212-554/558 115 LSA, LS6 Valvesprings, Harland Sharp Roller Rockers,Trick Flow 7.4 pushrods, NGK TR55 plugs, MSD wires, Melling High Volume/Pressure oil pump,LS7 lifters, Arp main studs-rod bolts-head bolts, Nelson's 93 Octane Tune, rear 02's and Egr Delete, BBK headers ito true 2 3/4 duals w/dual super 40 flowmasters, built 4L60E, Circle-D 3200 stall
  5. #15
    Quote Originally Posted by tatersalad25 View Post
    I would venture to say this guy got it figured out over a year and a half ago.
