Results 1 to 10 of 15
Thread: slightly bigger tires=super bad gas mileage?
    Oct 2009
    Idaho
    so several things have changed at once, and the mileage in my truck has dropped by 4.8MPG. (avg of 15 to 10.2 overnight)
    tires switched from 245/75/16 to 265/70/17, calculating a 1.1" increase in diameter. (also the rim/tire combo is heavier, but not sure by how much)
    temp dropped from mid 40's to below zero
    changed the oil (?)
    im thinking the only thing that factored my bad MPG was the tires. have you dropped MPG that much from switching to bigger tires?
    also the truck is a 1989 4x4ECSB 5.7, 700r4, 3.73. driving style has not changed, and measurement technique has not changed. earlier this summer i replaced the following
    CTS
    MAP
    02
    Plugs
    CAI
    Fuel Filter
    so i suspect those are not the issue. my engine is burning some oil, but has been for a while, and am planning a rebuild soon. i guess this could be a factor for my MPG, but like i said, its been this way for a while. any thoughts??
    1989 K2500 4x4, ECSB, 454TBI, 700r4, 14bSF, 3.73. 454TBI swapped, no cats, cherry bomb vortex.
    1990 Mustang LX 5.0, FRPP lowereing springs, 3.27's O/R X, Magnapack Catback, Explorer intake, 65MM TB, cobra wing
    How much heavier are the wheels? I know swaping from 15s to 22s made that much difference for me, easy.
    Oct 2009
    Idaho
    uhh not sure how much exactly. rims went from 16x7 to 17x9. a few pounds per corner?
    Rotating mass creates a bunch more load than you would expect. So a few extra pounds on each corner adds up and is a significant difference.
    Going from 16s to 17s "SHOULDN'T" cause 4 mpg difference though. Depending on the wheels, you're talking about 25 pounds added at the MOST. Then bigger tires, maybe 50 pounds total. Not like the 200 pounds I increased.
    True story. It could happen though......
    Plainfield, IL
    did you adjust the computer? Bigger tires actually go further then smaller ones...so if your odometer says 200, you may be going 240...which would increase gas mileage
    Weight makes a big difference. I went from stock 245/70/16 (about a 28") to a 36" tire, that is double the weight....my gas mileage went from about 24 on average to about 13 on average. (that is with speedometer adjusted)
    Nov 2009
    chicago, il
    10 lbs rotating mass is the same as 100 lbs total mass
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Union, MO
    I did something similar. I went from steel 235/75/16 to 2009 Tahoe 265/70/17's on my 2004 Silvy. I'm pretty sure mine decreased a little, but not really sure.
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
    Quote Originally Posted by gravedigger472 View Post
    This will cause a noticeable decrease in mpg, especially if your mileage is based on around-town driving and not highway miles. Colder air requires richer fuel mixtures, and it takes longer before the engine achieves closed-loop mode, where the O2 sensor controls the air/fuel ratio. Depending on your type of driving , 4+ mpg decrease is not unreasonable.
