Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 81
Thread: Guess my total HP!
  1. #11
    .....and our next contestant is...?
    Hey Dave, I didn't know 22 year-olds knew about TPIR.
  2. #12
    Sallisaw OK
    530
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
  3. #13
    Im gonna go with 526....
    Nathan--Yes us youngans know about TPIR....even know who Bob Barker is...I mean that dude is only like 175 yrs old now...
  4. #14
    I'm guessing somewhere north of 37 HP.
  5. #15
    what were the actual numbers in your sig? 5** rwhp 5** tq ?
    has there been changes since then?
    whatever those secretive numbers are i figure just slightly higher
    Simple: 408 on steroids!
    single digits coming soon!
  6. #16
    Winnipeg, Manitoba, Canada
    570
  7. #17
    haha I know what TPIR is.. its not a good show anymore with drew carrey..
    James why wouldnt your numbers be higher then the previous ones?
    He didn't know about a fine toothed comb so I was surprised.
  9. #19
    Oct 2008
    Houston
    Quote Originally Posted by Jamest View Post
    Went to Allen's to pick up my truck! Allen had a problem with the fuel delivery. He said at 10 psi and the upper 4XX hp it was running out of fuel. That is insane! So he is going to keep the truck a little longer and put an A1000 fuel pump on it!
    Any guesses on the final wheel HP?
    I'd say 510hp?
    Jamest
    6.0L with a T-76 running 10psi should bump 575-600rwhp mark even with an automatic.
    btw: those A1000 are LOUD !!!!!
    You might want to consider running dual external Walbro. instead.
    If you are hung up on using the A1000, look into the Aeromotive Eliminator pump instead.
    It is same size and shape as A1000, but flows 20% more and has bigger inlet and outlet fittings.
    I run one on my Stang, nice pump.
    If you ever want to turn up the boost the A1000 is already maxed out on a forced induction
    engine at just over 600rwhp.
    2002 Tahoe 4.8 - soon to be turbo'd - SOLD
    1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
    2012 Raptor - 497rwhp at 10psi
    If you aint breaking - you aint going fast enough
  10. #20
    Jan 2006
    The old numbers were 475.7 hp with the setup that you have now. I put 5XX b/c I didn't know hat the final numbers would be on the new setup? Kind of a guess?
    Jamest
    12 Sec. Club! SOLD
    SOLD***
